[FOR SALE] 65 Barracuda Top of Quarter Panel Trim
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I pulled this top of the quarter panel trim from the 65 Barracuda I’m parting out. It’s stainless steel and I “think” they used stainless for 64 as well. I “think” for 66 the trim changed to aluminum. It should fit the 66 as well but may not be correct. $50 for both pieces plus shipping from 22657.
Won't fit '66 (a bit longer & wider) and '66 is aluminum whereas 64 65 is stainless steel.
With just a little alteration, it will fit the 66 as well! The end needs to be opened up a little to go over the larger tang of the 66 taillight, and I believe the clips are different! Changing to the stainless trim on the 66 is, or was , the new hot ticket, as the aluminum spears are usually dingy, and easily dented!!
