65 cuda wiper motor wiring
waggin
moving on ain't easy if you drive a Ford :p
Floral City Florida
I really need a wiring diagram for this car with color and large enough for me to actually see it or help telling me what colors go where I have retrofitted it and the wipers will not park/do not switch direction, the switch and the motor work fine on my waggin but I cant get them to work in the cuda witch the wiring harness has been modified.......HELP!!!!! :violent1:
does the tan wire ( v 10) go to washer bottle motor? and yes I can see this diagram all the others were so small I couldn't read them Thank You!!!!!
Got them working now turned out to be the switch has to be grounded I have been messing with these for some time and never thought that needed to be grounded also Thank You Keith
Waggin just for your info V10 does go to the washer motor through connector pin F.
Glad you got it working...
