'65 dart A904 leak
65Dart67300
Member
Orange County, ca
I've got a transmission leak in in my 65 dart with a floor shifter and cable shift selector. It looks like the leak is from where the kickdown lever connects.
Does this transmission have the same seal that is used on later transmissions?
Anyone have a recommendation for a transmission shop in the orange county (CA) area for this work?
Yes, there is a lip seal there. Don't know if it's the same part as the later transmissions, but same idea. It's just a bigger PITA to drop a cable shift valve body to replace it.
not the same seal as the newer ones. Looks kind of like a funky O-ring. you can pick the old one out and replace without dropping valvebody.
Throttle Lever Shaft Kickdown Seal TF6 TF8 Torqueflite 6 8 727 904
