66 Dart Hood Hinge question
rod7515
Red Lion PA
I was wondering if the Hood hinges can be removed without taking off the fenders and also does anyone make a spring hinge in the aftermarket world.
Thanks Rod
You might be able to remove them after removing the rear splash shield and if you can get your arm up there to remove the hinge retainer - maybe!
and also does anyone make a spring hinge in the aftermarket world. Thanks Rod
Haven’t seen one - yet. I am going with hydraulic lifts after removing the hinge torsion bars. It’s much easier to secure the lower lift bracket with the fenders off but I suppose with a right angle drill, it could be done with fenders installed and rear splash shield removed.
These springs came out of a duster and I machine these brackets myself
Wow great work lilwarlock!
That looks real nice and it looks better than the lift shocks I used.
