66 Plymouth Valiant [Frontend Info Needed ]
NCmtnDWELLER
Cartoogechaye - NC
What is the best source for a rebuild kit and should poly be used over conventional rubber products thanks .
I used poly on my 65 Barracuda front end and hated it.It was stiff and squeaked every time I went over a driveway apron or speed bump. This was back in the mid 90's when they were just starting to push it .It may be better now but I'll never find out.I go for OEM
Ten 4 , thank you Sir
Please let me know if you have any questions on any of the products that PST offers. We offer bushings in both Polygraphite or Rubber. Also remember to take advantage of the forum members discount when placing an order.
Thanks
James From
PST .
Thanks
James From
PST .
Yes sir
Thank you
I have Poly on my 66, used it on the last 3 cars I put together. make sure you lube it when assembling and you wont have squeaks. ( or at least I haven't )
im running 73 up style disc's and larger torsion bars ( PST 1.03 bars ) much firmer than stock.
Thank you for the good info.
