[WANTED] 67, 273 exhaust manifolds
want to buy casting numbers: 2780945 (left) 2843953 (right) preferably sandblasted.
I have set still on a motor I pulled, I can sandblast them. [Please use the PM feature to exchange phone numbers] give me a call if still need. Located in SE Iowa and have several 60's mopar parts, barracuda, coronet and misc.
Am interested in your exhaust manifolds. I have acquired a 67 Barracuda f/b formula S 4 spd. It is supposed to be a 273 Commando which replaced by a 340. I am piecing a 273 together and trying to get engine parts not newer than Mar 67. Got a late 66 "long block" lined up in Arizona. I still need exhaust manifolds, finned valve covers, chrome breather, afb carb, pulleys, brackets and flywheel. If my block deal fails, I need everything except a distributor and timing chain cover. Tell me about your engine that these manifolds are on.
Checked #'s - have the right, (2843953) but it is a later date code.
Other #'s are:
2465719 (2) date codes appear to be 11 15 7 (67) and 12 22 7 (67)
3512077 can not find date code
3671398 3-1-74
Good luck in search
I have a set with those numbers, not blasted, came of a barracuda 67 hp car, heat riser is free and works. 50 + ship
Heres a close up of the numbers. one is very readable, the other, not so much. you can see it is the correct number though. Was the original set off the 273
I've got a 2780945, blasted around 10 years ago. $25 plus shipping from CT.
My fault, thought this thread was from July 2016, sorry.
