[SOLD] 67 - 68 steering and susp parts
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
I have a bunch of parts leftover that I don't need . If you do let me know . These will fit more years also.
Lower Control arms, no tabs, bushings look good. $75
2 Pair of drum brake spindles $50 each
2 pair strut rods ( straight ) $50 each
2 V8 center links $50 each
1 pair drum lower ball joints , feel tight. $25 pr.
68 & up Idler arm all tight . $40
Pitman arm , off the 67 but I think same as other years. Joint is tight also. $30
2 sets of tie rod assy. They are tight also. $30
All plus shipping from FL. Paypal . Make an offer on a bundle !
Also have 2 sets of drum drakes from same cars. All drums are good . One set of hubs have the studs tack welded in. ????
$40 for the tacked set
$60 for the other set.
set is drums , hubs and backing plate.
Thanks for looking. AL
I also have a pair of small ball joint upper control arms from the same .
$65 shipped in the US.
SOLD last pair of spindles. Still have the other parts. Thanks AL.
