67-72 Drivers Side 340-360 Motor Mount Bracket Shim Question
e50095
Goin' 318 to 340. I understand the passenger side is cool. On the drivers side, how thick do the shims need to be, and am I moving the bracket and biscuit toward the firewall or toward the radiator? I assume I need 2 longer bolts to go through the 2 shims. Thanks guys, no cash for Schumacher so the shim route is for me. I'll use that $150 to upgrade the ignition.
My Barracuda thanks you for any info you can provide.
I just used a 318 mount. the front 2 mounting tabs are the same, it's the top back mount that is different. I used 4 thick flat washers to shim mine, with a longer bolt. You can go to your local hardware store to get the bolt and washers if you don't already have some.
