67 Barracuda Build Sheet Decode
Powerflite
Southern CA
Can someone help me decode this broadcast/build sheet? It was under the rear seat in my car, but doesn't match my VIN. So if anyone recognizes their VIN here, let me know, and I'll send it to you.
I think it belongs to a 1967 Barracuda fastback but I can't help any more than that. My decoder book only goes back as far as 1969. Bobby
The D after 29 is 273 cu in., 2 after the 7(year) indicates it was built at the Hamtramck Mi. plant and the vin is obviously 378775
Based on my dart (my dad special ordered it) never hot rodded. 98% original
Dist 35 point dist most likely CAP
Sway bar 0 No Sway bar I have a 9 in that field and have factory sway bar
Rad 73 radiator 2785 973 or 2785 970 (CAP and high alt or AC)
Engine 365 273 2 bbl
Trans 534 904 automatic
Axle 607 7 1/4" open
Pinion 31 2.93 to 1
Front brake 12 10"drum my front brakes are 19 and KH disk
In blue
Radio 1 music master AM
If tire is 215 - 6.95x14 black wall
In green 31 5 2 are the same as my dart.
So engine trans and axle same as previous post.
Cleaner Air Package 1 CAP car might have been a California car or where the CAP package was required
H. D. Brakes police /disk 6 I assume that's 10" front drum I have a 9 in that spot and KH front disk
Cigar lighter 7 mine is the same and has an in dash cig lighter
Glove box lock 9 locking glovebox
Map light 1 under dash map light
Tinted or clear glass 29 clear glass tint across top of windshield
The number under the tire section is 235
That's what I thought.
I have seen books that list the tires codes
Probably same size but white.
235
23 = 6.95x14 white side wall .
5= 5 tires ie a spare.
215
21 6.95x14 Black side wall
5 = 5 tires
