'67 Barracuda Fastback courtesy lamp replacement
G-Fish
Tucson
How do I remove the lens to replace a burned out bulb?
Rotates either cw or ccw. I believe ccw. There are 3 tangs in there. Do yourself a favor and please disconnect -ve on battery 1st.
While you are "there", chk to see how close the bulb holder is to touching metal. Also chk condition of bulbholder, they are plastic and VERY brittle. You may want to install an led to reduce the heat/load.
Good luck
I don`t remember it screwing out, I remember squeezing the sides where the tabs are and they come out of the slots that hold them. Careful when you do it.
