67 Cuda w/BBP discs suspension kit
ESP47
Sacramento, CA
I'm doing a 73+ A body BBP disc conversion on my 67 Barracuda. I know the ball joints are going to be bigger for sure. Are the upper control arm bushings any different? Also will I need a different lower ball joint? I'm assuming the rest of the suspension pieces will stay true to the 67 suspension, right?
Thanks, looks like I need the 73+ upper and lower ball joints as well as upper control arm bushings. Everything else should be 67.
I was wondering because I was going to call PST and see if they could put together a mix and match kit for me instead of having to buy everything separately.
