[WANTED] 67 GT Dart rocker panel moulding+more
GT67dart
Member
Finland
Another lost soul here looking for a matching pair to 1967 GT Dart rocker panel moulding(rumour says a snowbank took the passengers side back in the 70s), or I'll even buy a pair if found.
Also interested in other trims/mouldings, new windshield, small block stroker kit to supercharged 340 and holley sniper efi carburetor.
I may have the single rocker trim. Not sure which side I have. Ill check
I also have a lot of belt line mouldings.
Thanks for the quick reply Al! I'll have to confirm which side I have in the garage as I've never actually had it on. Hoping for a lucky break this time. You don't happen to have the pieces for the front fenders? As for what comes to rest, I'll check the condition and which pieces I'm still missing.
I just got finished going through all what I have.
I do have a single rt side rocker, that is dinged up some, but I think can be worked back into shape.
And a few extra fender pieces.
O
Mine looks really done and dusted, I cant really make out from the photos if it's the same side or not. What do you think Al?
yes look the same ! If the lower pic is the front edge , then mine is for the right side ! It is a little dinged up !
I do have some fender trim also !
