[WANTED] 67-??? plastic drivers / passenger door glass slides that go into vent window frame
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Hi all
I'm looking for a clean sample/s of the OEM 67 - ??? slides. My intent is to reverse engineer them as the white plastic ones available from time to time do not seem to fit like the originals. I have 4 from my drivers door of my 67 Dart but they are highly warn where they slide in the frame.
I would also love to get a clean undamaged seal part with the felt still attached. The one I have I can not tell if the plastic is as originally manufactured / installed or if it has missing pieces from wear.
OEM 67
Left is newer style, right is OEM 67
