[FOR SALE] 68/69 HP manifolds big block
baracus
ga
Rating - 0%
0   0   0
Set of b-body 383/440 hp exhaust manifolds.
350.00 plus shipping
Passenger side reproduction hp manifold, new. Broken heat riser. 125.00 plus shipping
Ships from ga, paypal only.
Great price. FYI, these are the manifolds that will fit on low deck engines in both early and late A bodies with very little modifications.
Tried to pm you. Site won't go. It says error. Btw, thanks for the intake deal. Maybe you can pm me? Thanks, Mark
What type of mods? Angle mill the mounting flange?
No that only needs to be done on the C body HP manifold. The B body drops in on the passenger side and the driver's side requires the steering column outer shell to be trimmed back nearly even with the firewall and the shift linkage arm from the column removed. That's usually all. It's outlined pretty good over on BigBlockDart.com and other places.
Thanks!
