[Found!] 68-72 Left/Driver Window Regulator
grfelix
New Member
Rating - 0%
0   0   0
Hello, looking for a good working left/driver door window regulator for my 1968 Dart. I believe the 1968 to 1972 two door Dart, Barracuda, Valiant, Duster are compatible. (Not sure if 1967 is the same).
Shipping to southern California 92932
Thank you
You can re-weld the missing teeth on the regulator arm where they were stripped cause it was never cleaned and or lubricated.
Make a template of the gear teeth pattern, and grind them back to fit after the wire feed adding the missing material.
Lube them up good so they work nice, wash out the dirty dusty window channels too.
Used regulators are going to have the weak worn teeth too, especially the driver's side.
Skill level > 7 Plus...
