[WANTED] 68 Barracuda door jamb lock pillar
v1rot8
New Member
Montgomery, TX
Rating - 0%
0   0   0
Hey,
I know it's a shot in the dark, but AMD does not repop it. I need a driver's door jamb lock pillar.
The car was hit and had a lovely lapped quarter half and the pillar lip was cut off to allow it. The finished it with a 1/4 inch or greater bondo.
I have one that I cut out a parts car, but didn't cut the full part out. So, I'll have cut and weld it in. Just seeing if there is someone with a full one, it may make my job easier and a better fix.
Thanks,
Brian
Hey,
Thanks,
Brian
Do you need the panel that holds the door striker on the quarter panel? I have one I cut out of a 1968 Dart. I believe it is the same on the Cuda. Let me know.
Thanks, but as toplscuda stated, they are different. AMD repops it for the dart/duster and I called them to see if it would work. They said no, they are different.
