68 Dart GTS roller project sale/trade
dartforforty
Legandary Member
Legendary Member
South Jersey
Rating - 0%
0   0   0
1968 Dart GTS race car project
Car was profesionally built
12 point chromoly cage
2X3 ms rear frame rails tied to NOS front frame rails
4 link with panhard bar, new Strange coil overs
9" ford rear housing, New Strange nodular center section .430 gear with a spool,new 35 spline Strange axels,new Strange rear disc brakes
New Alterkation front suspension, tubular upper and lower control arms, rack and pinion steering, with Wilwood disc brakes
Rear quarters replaced as one piece with 67 Dart rust free rear clip
Car still needs final tin work,trans tunnel and cross member fabricated, plumbing and wiring.
Car will come with 67 Dart steel fenders and grill
67 Dart tail lights
new 20 gallon aluminum fuel cell
68 Dart dash frame with Rocky Mountain insert
15X15 Weld Pro Stars,on rear with mock up tires.
fronts are just steel rollers
Have front and rear glass not installed, quarter and door glass is there
Set up for big block, motor plates will come with car
Have a clear New Jersey Title
Car is located in Central New Jersey
E-Mail gmtochrysler@hotmail.com
$15,500 obo. open to Mopar trades 62-65 B-Body, will consider other Mopars
I'm going to part this out if it does not sell whole.
Alterkation front end is sold if the body sells first.
After 12 years and getting ripped off by 2 fabricators, I've come to the conclusion the car was not meant to be for me. Time to move on in another direction.
Dash insert is by Rocky Mountain dashes. I used a dash cap on an old upper pad and cut it to fit the roll cage.
Please let me know if you will part with the Rocky Mountain Dash Panel. I have searching for one for some time now...Thanks
