Sdriche
In the process of removing my lower control arm for rebuild, the nut from the pin fell somewhere in the engine compartment and I cant find it. Are these bolts easily replaced or are they a special size? Thanks in advance.
x2 with the confusion...Are you talking about the nut that holds the pin to the k frame?
