68 Dart to 74 Dart brake swap
DragginMAster
Fayetteville, AR
Am planning on putting disc brakes from a 74 dart on my 68 Dart
my tir rod ends are crap at the moment.
I have, or will have the arms off a 76 dart. I have Spindles from a 74 ( but I can get the spindles off the 76 as well if that would be better or if there is no difference)
After swapping though, should I use tie rod ends for the 68 or 74/76? The auto parts store has them listed as separate parts with a substantial difference in price.
if I use the 74 / 76 tie rod ends, do I need to use the center link and what not as well?
Spindles are the same for those years, You will have to use the upper control arms as well, and you will get the larger upper ball joint. You should take the master cyl, and prop valve from the 74. I beleive the center link is the same 68 - 72, 73 - 76 is the same. Use the lower ball joint from the 74 as well. Basically take all from your 74 donor.
i already have a master cylinder for a 68 charger installed.
I already know about the control arms and upper and lower ball joints
the question is about the tie rod ends and center link. I have only heard people talk about the arms and spindles, never really heard them mention the tie rod ends and centerlinks and other steering doo dads.
