68 Dart Turn Signal Wire ID needed
Mopar2
Three Rivers MI
I am replacing the wire harness on my 68 dart. I am in need to know what wire is what on the wires going from steering wheel to connector at the base. I see there are a total of eight wires and are in two groups each of four. The first group is colored Brown, White, Red and Orange. The second group is colored Black, Green, Tan, and Brown. I have attached a picture of the wires to help, once again they are the wires for the turn signals that go from the steering wheel to plug lower on steering column. I need to know the ID to hook them up to my new harness which is labeled.
thanks!
OK, this is from the '68 Service Manual:
Steering wheel side of connector
Pin # Wire Color
1 Light Green
2 Red
3 Tan
4 Black
5 Orange and Brown
6 Dark Green
7 White
8 Brown (same wire also connects to pin # 5)
9 (no wire)
10 (no wire)
Pin locations:
6 1
7 2
8 3
9 4
10 5
need to know what each wire is, I can tell what color they are by looking at them. I putting a new harness on and need to know what wire is what, for example they should be horn relay ground, left frt turn, right frt turn, turn sw hazard, brake switch, turn switch feed etc etc. The wires are labeled on my new harness just not the old where the connection will be
