68 steering column shaft
Do you know what length you need? I have a couple of spares but don't know what they came out of except they were A bodies.
I will check the length. I do know the p/s shaft is 4 in. Shorter than the standard. I need the shaft with the top and lower bearing. Thanks bud
column shift or floor shift? i'm doing just the opposite-- converting to manual from p/s on a 69, Lawrence
