69 340 valve covers ?
nutz
washington nj
is there anything special about the oe valve covers ,i heard they make repops .....
On 69 340 engine valve covers, Passenger side has a heat shield to protect the alternator and temperature sender wires from heat damage and the drivers side has a taller loom bracket at the rear of the cover to clear the ignition wires from the throttle cable along with the kick down linkage. Other than that much the same as 273 or 318 2 barrel engines.
Hope this helps
Thanks
So they are different
What year 340s can I use
AMD was selling repops, not anymore I believe. 69 340 is 1 year only of course lol.
If you can weld, you can very easily "make" a 340 set. As Noel said abv, pass side has a cupped loom/wire holder. Driver side has a much taller bracket for plug wires, so to clear the 4bl linkage etc.
does anyone have picks
are they the same as 68 except the wire looms ,looks like pcv only on the pass and the breather/oil fill on the d/s
thanks
