69 Cuda Rear Tires
MOPARJ
What can I upgrade now?
Thousand Oaks, Ca
Hey y'all. I have 14 inch cragers on the 69 Cuda. I need to replace the rears, as they are weather checking fairly bad. I would like to run a taller, somewhat wider tire on the rears. Im at work and can't look for sure, but i believe i have 235/65 or 70/R14's right now. How far can i resonably go to using 14" rims without having clearance issues? Thanks.
I have 14x7 americans with 4" backspace with g-60-14 Mickey Thompson Indy profile ss tires. they are 25.3" tall. They are ok with good stock springs. 26" or 27" will probably be the tallest you can go with stock springs. 27" is probably pushing it.
