1969 dart 360 833 od 4 speed dana 60 gts clone originally it was a automatic six
Body was repainted in 96 with base clear paint but has been outside and driven a lot since it has a gts hood good front fenders comes with spare doors and quarters cut off another car
interior is ok seats where reskined the front carpet is out because the windshield leaks it has a 4 speed Colum with a autometer tac and oil pressure gauge mopar chrome ignition box and tach drive dist.
Engine is a stock bore 360 that was pulled from a wrapped up diplomat cop car years ago it has later model heads 308’s off a fuel injected engine not magnums performer intake holley 750 ati balancer and a racer brown hydraulic stick cam I forget the spec off the top of me head but it’s in the .500 lift range it has a nos 150 shot of nitrous that still never made it through the first tank it has little tube headers with a 3 inch x pipe and mufflers going into 2 1/4 tails ½ aluminum fuel line with a holley blue pump aluminum radiator
Trans is a stock 833 od from a truck with a aluminum front and a older style side cover Hurst comp plus shifter a steel scatter shield and a diaphragm clutch I forget I think it was a ram
Rear is a dana 60 hd truck case that has been shortened to stock a body width 4:10 gears power lock posi 35 spline mark williams axles the driveshaft has 1350 joints and a dynotech 4 inch chromemoly shaft
The chassis has super stock springs in the stock spots with a pinion snubber 6 cylinder torsion bars big bolt disks up front with a line lock 11 inch drums in the rear and a aluminum master and frame concetors it has cop car wheels and poverty caps with leaky mckurey cheater slicks
I don’t really want to sell this car but I hate to see it sting there going to **** the price is firm but can come down by me removing parts the car runs and drives and ran 12.20 at 112 last time a out $4500.00
Thanks Ray RBohadel@aol.com
here are some pictures I will take some better ones soon http://s247.photobucket.com/albums/gg121/NoFrillsPlymouth/dart/
