69 Dart -- front fender hardware
George R
Mopar Nutcase
Trumbull, CT
I'm trying to sort out the hardware for the front fenders on my Dart. The car was disassembled by the previous owner, so not everything was bagged/tagged correctly.
While looking through the bags of hardware, I found the 4 plastic push-in fasteners that accept the screws to retain the headlight bezels. Two of these plastic parts are broken and need to be replaced.
Does anyone know a vendor that sells these parts? I can't seem to find them listed anywhere, in any catalog.
Second question relates to the bottom of the fender behind the tire where the round shims go. Should these pieces of hardware be studs/nuts or bolts, or one of each?
Again, I'm sorry if these are obvious questions, but I'm still learning my way around an A body, and also cleaning up someone else's mess.
Thanks for all the help so far guys. It really has made a huge difference.
George
Hi there.
Check this website out: http://www.rtspecialties.net/
There are lots of different fasteners on this website.Hope this helps you in your search.
I also have a 69 Dart Swinger 340 that is in a restoration process,slow going though-money wise.
By the way... great job on the Dart.
