69DODGEDARTGTS
Member
1969 Dodge Dart GTS
Clear Kansas Antique Titled, Located in Wichita KS 67204
Dark green paint, black hood, black vinyl top, black interior
Really stout 340 small block V8, Holley Double Pumper 750 carburetor, Weiand Intake, 360 J heads, lopey cam, MSD 6AL ignition, Mallory 250 high flow fuel pump with regulated return, new 1/2" fuel lines, new Mopar Performance valve covers and air cleaner, long tube headers, 3" exhaust, Flowmaster 40 series mufflers
New aluminum radiator and electric fan
New aluminum fuel cell with sending unit for fuel gauge
Built 904 transmission, 3800 stall 10" converter, reverse manual shift valve body, Winters drag race shifter
Narrowed 8 3/4" rear end, Moser Engineering axles, Auburn Gear limited slip carrier, 3.73 gears
Mini wheel tubs, leaf springs moved inboard
Full roll cage with hinged and pinned swing outs at doors
Subframe connectors
Weld Racing wheels, Mickey Thompson street tires
Line lock on front brakes
Battery cut-off switch
5" tach with shift light
Good glass, doors and 1/4 windows roll up and down good
New tie rod ends, ball joints, alignment, etc.
Adjustable CE drag race shocks
SERIOUS INQUIRIES ONLY
$16000
Subframe connectors
$16000
