bc67barracuda
1967 Barracuda - Fastback
I have a 1967 Barracuda with a rebuilt 273cu. motor bored .30 over(might be in the low to mid 200hp), edelbrock intake, edelbrock performer 1406 carb, Comp Cams Hi-Tech 5/16 .500 push rods, Ultra Pro Mag rockers, Edelbrock Perf plus hydraulic cam and lifter kit(RPM range idle-5500), headman headers, 904 automatic, 7 1/4" rear end and 215/70/R14 Tires. Wondering what gears to use as this is a casual street cruiser and sometimes freeway. My research indicates 3:23's to be a good overall setup? I believe I have the stock 2:76's in now and at around 3000rpms I'm at 60mph. There is absolutely no launch off the start so I would like to get a little more off the line and not to have the car sound like it is going to blow up on the freeway. I was also told that a 2500 stall converter would also help but the gears right now would wake this engine up. Thanks in advance!
