70 dart scoops
justswinger
Member
Im new at this need help where do I get info to do work properly on a project. My son has a 70 dart wants to mount the 340 scoops on hood I think I see where the large hole in the hood goes there is a cut out on the strut under the hood but what size is the hole to be cut. Also where is the proper scoop location on the top side of the hood?
thanx for the help if I get responses like this all the time my sons project will go alot easier good work burntorange70
do you know the size of studs used to mount the scoops we have the scoops but no mounting hardware
I would like to know what size and thread are the original anchors I think they are studs
I could not tell you. Never had mine off. You could try taking a scoop with you to the hadware store and seeing what screws in there. Mabby get some all thead and cut it down to the langth you need. If that don't help you. Keep bumping this post up. Mabby some one will see it that knows.
