[FOR SALE] 70 Dart. Swinger
Ed Quinn
New Member
S C Wisconsin
Rating - 0%
0   0   0
Rotisserie rebuild in 2007 everything new. Altercation front, triangleated 4link in rear, minni tabbed, disk breaks all around, frame tied in several spots, 6 pt cage, interior gouges custom, dash pad, stereo, subs, Amp, ect. Engine, Trans and paint just redone. R3 stroked block, 444 ci, 1043 hp, 928 tq. F1 procharger, set at 10lbs boost, indy heads n port matched intake, e85 Mark Sullins carb, comp manual roller cam, Cali crank, kieth black rods. 373 gears, 727 trans w all good stuff. More stuff I'm sure, runs high 9's in garter. Haven't tried w new setup. 75k located in S C Wisconsin
The dyno sheet shown is labeled for a 331 cu in engine. Is it a true sheet from your 444 cu in engine just mislabeled? How much boost did it take to make 1043hp?
I thought he told me it was 444ci, no way it is 331ci, i will ask again. It made 10 lbs boost and is tuned with that pully.
