[SOLD] 70 Duster 340 w/ 20ft Pace Trailer
70 Buster 340
Carbon Footprint
Legendary Member
Space Coast, FL.
Turn key, Ready to Run, add gas and go.
Health forces sale.
$16,500 or best offer over that.
1970 H code 340 Duster and 20ft Pace enclosed trailer and everything that goes with it.
Load up, Ready to race today @ 2910 Lbs. less driver
Great car, add gas and go.
Solid Southern Life / Central Florida race car since 1984
Was original Orange 4 speed, Manual steering, manual disc brake, bucket seat car Still has 3 pedals.
Does everything it’s supposed too. Hooks great, goes straight, runs clean trough the traps, stops straight, charges.
Built as a 11.99 car to run round robin in the heat, had two good paying IHRA classes but that track (Palm Beach Raceway) closed down.
Sportsman ¼ @11.99 and No Box 1/8th @ 7.50
Been doing test and tune at my local NHRA track.
Time slips post below.
I’ve been taking it pretty easy on the car, 3000ish rpm footbrake launches, shift at 6000, trap at 5900-6000, short time in the water box as these tires don’t need it.
I had a saved draft disappear, so I'll post this and then more descriptive text and images below.
Trailer
Dry and fully equipped to go to the track,
5 new tires,
brakes good,
winch,
storage cabinets,
sink w/ new pump,
straps, race fuel can, air tank,
12 and 110 volt interior and exterior worklamps,
LED interior and clearance lighting, 110 inverter,
microwave,
banners.
recent 65 series battery.
Ready to go.
Is a Buster like a Duster?
You don't say but do you have the titles to the car and trailer?
Any under hood pictures or interior pictures.
Sharp car.
What times and mph does it run?
Sharp car.
Car has been a off-road racer here in Florida since 1984, it was never retitled or registered and put back on the street since.
I have the Florida Title but it was signed and closed on 7/27/1984.
I'm the third owner since 1984.
The radiator support number matches VIN tag and Title
Trailer Title is in my name, just renewed tags.
Trunk
New 10 gal fuel cell with 90 ohm level sender connected to gauge.
Single or Dual AGM batteries vented thru floor.
Trans cooler with blower and dual temp sensors /
gauges.
1970 date 340 w/ 2.02 X heads, 20 runs.
Professional built by Vic Fera
Eagle rotating kit balanced
MP .484 hydraulic.
Crane iron adjustable rockers.
Chrysler LD4B port matched
Holley 750 DP.
MSD w/ 2 step and chip sets
Moroso electric water pump, 10 and 14 tooth drive pulleys.
Push front and rear pull electric fans.
New water pump, alternator, MP regulator, distributor.
Great OEM radiator. New hoses.
20 passes on new motor shifting/trapping at 6000 rpm.
Trans:
727 RM valve body and JW 8" convertor
32 runs on fresh rebuilt and New 8” JW convertor.
Rear
8 ¾ , 742 w/ 4.30 and spool
New replacement drive shaft
Underhood pictures
1- Is a Buster like a Duster?
2 - You don't say but do you have the titles to the car and trailer?
3 - Any under hood pictures or interior pictures.
4- Sharp car.
5- What times and mph does it run?
1- Duster is in better shape than Buster :(
2- See above
3- See above
4- Thank You !
5- See here
Old and out of practice driver, easy launches, 6,000 shifting, there is more in this car.
So the title to the car is signed, but you never registered it?
Has anything been done to the bottom end of the engine
New Eagle forged rotating kit
Stock stroke 3.31 / 340
0.30 over
Balanced
Professionally built by Vic Fera -
MP 284/.484" cam
Melling HV pump
OEM windage
Fresh 20 runs at 6000
Basically a streetable / very low maintenance strip combo
Wheels and Tires:
New Goodyear 9x30x15 LWR lightweight tubeless radials. 8 runs
Dead Hooks with these radials at Goodyear recommended 22-ish psi without a big burnout.
New 165/80r-15 87T 118 MPH rated radial fronts. Tread still has tits, even wear pattern.
Wheel halves wirewheel stripped and resealed
All speed balanced great with very little weight needed.
Slicks double treated inside with Palmolive
All tires hold air
Not screwed, don't move at the higher tubeless pressures
Small bolt
New Valve Stems, Steel Bolt-On
No center caps
Doesn’t sit on the tires. When not in use car always kept on jack stands in the garage.
0.30 over
Balanced
MP 284/.484" cam
Melling HV pump
OEM windage
Vic Fera was a good friend of mine and owned Brevard Cylinder Head. He was my go to machinist until covid got him. Bob is also a good friend and I've enjoyed many evenings at the track running my car with Bob. If I had an extra parking spot in my garage this thread would never had happened. Car is meticulously maintained and a great package for someone who wants to go racing.
I don't understand what "signed and closed" means regarding the title.
Car was last sold by Don Mealey Chevrolet in Orlando FL. and signed over on 7/27/1984 to an individual that never re-titled the car because it was intended and only used as an off road race car ever since 1984.
There are No Liens on this car, not stolen or salvage.
Local DMV confirmed that.
Full VIN # removed for security in this post
VINCheck® Lookup | National Insurance Crime Bureau
About VINCheck
www.nicb.org
www.nicb.org
VINCheck® Results​
VIN: VS29HOB323xxx
VINCheck® Theft Record​
VIN: VS29HOB323xxx has not been identified as a vehicle listed in the VINCheck® Theft Records.
VINCheck® is updated regularly as additional information is reported.
VINCheck® Total Loss Record​
VIN: VS29HOB323xxx has not been identified as a vehicle listed in the VINCheck® Salvage Records.
