70 Duster power brake conversion
Chris 340
Member
Denison Texas
Hello everyone. I have a 70 Duster with a 340. Front discs rear drums. I would like to convert it to power brakes. I bought a power brake booster and master cylinder assembly which should bolt right up. Will i need to install a proportioning valve, or will the factory metering valve work?
I had manual front discs and drums on my 70 Dart 340, and found the correct booster and master cly. Installed using stock proportioning valve.Works Great.Pictures are in Photo Garages under Ricks70 Dart if you would like to see.
