71_dart_swinger
Time to let go of my 71 Dodge Dart swinger. Original slant 6 car.
440 .30
516 heads. Ferrea valves
Harland Sharp rockers
Howard’s hyd roller .565/.565
295/305 duration
Torker 2 intake
Brawler 950 carb
Full length under car headers/ 3” h pipe and black widow exhaust
Built 727 tranny with reverse manual valve body. Converter flashes @ 3800 rpm…nitrous express plate kit. Currently 150hp jets
Msd 6am2 digital ignition. Bullet distributor locked. Dual fuel systems both with Bosch 044 pumps and aeromotive FPR. 8an braided lines for motor /carb system. And 6an braided line for the nitrous system ..
Oil accumulator
Rear end is narrowed and braced 8.75 that was just completely rebuilt. 4.30 Richmond gears. Mopar performance seals and bearings. Ssbc disc brake conversion. Caltracs rear mono leaf set up. Welded sub frame connectors .front end was completely rebuilt 2 years ago. Front end is also disc brakes. Has a mini tub to fit 29.5x12.5 tire if need be. Currently has 28x11.5 Hoosier qtpro. Driveline hoop.I do have dash cluster . And door panels. Exterior kill switch. The car is not perfect. But it’s a great solid car. The only thing original on the car really is the body and glass I’m missing a bunch of stuff. Looking to get $15,300. OBO. ..Clean title in hand. No I don’t need help selling. And no I will not take 10 for it.
Sean phone number removed by staff. It's against sale rules and best for your internet security. I will respond to text messages/ and will respond to phone calls. Just leave a message. Don’t waste my time. As soon as I feel my tune is being wasted I’ll drop communication and block you.
440 .30
295/305 duration
Torker 2 intake
Brawler 950 carb
Oil accumulator
