72 Dart window problems
72dartcustomhawaii
New Member
Honolulu
Aloha..I have a 1972 Dart Custom here in the islands and am hoping someone can help me solve a problem with the driver's side window. The window is very hard to crank up or down when half way down. I took the panel off and greased and lubricated all the moving parts, but the problem persist. Is there is a simple and quick way to fix this versus taking the whole mechanism apart? Apprecate anyone advice who might be familiar with this problem. BTW, my car is a 4-door custom, v-8, green with vinyl top, a/c, power, etc, and has only 56K original miles. A real survivor.
Probably dirt in the rubber track that the glass rides up and down on, use some warm soapy water and try to get a small scrub brush in the groove.
ok thank you. now that you mention that i bet that's teh problem as the car was parked under a tree for a but and had some debris on it. I'll clean out the tracks and hopefully that'll fix the problem. really appreciate it.
