72 demon e brake cables interchangability
I believe any Duster, Demon, Dart from 70-72 will work. I got my cable set from "the right stuff" from a car show. I paid 120.00 for all 4 cables and hardware.
I believe it will have to came off of any 72-76 A body. They changed from a single cable in 71 and older to a dubble cable 72 and newer.
Some one correct me if I am wrong on the dates for the change.
Does anybody know the exact lengths of the two cables? I know they should be the same size but would like to know the length before buying anything that might be questionable on whether it will fit or not.
does anybody know the correct lengths for these cables?
Can't help with length. The intermediate cable for the 72 Duster/Demon is different from the Scamp/Swinger due to different wheel base. So figure the one you need is the shorter of the two A-body cables. The correct cable originally carried part number 3467 906. This appears to be a running change as models made before 11/15/71 don't use this cable. The 73 uses the same cable as the 72 models made after 11/15/71. Hope this helps.
