I am trying to put my park brake lever back in my car. It appears I have about four parts. One is a small bracket (square C shaped) and I can see where it gets a tab rotated through a slot in the frame and it has a nut and through bolt with it. In the book, they call it a clamp. The other is a spring about 1" diameter and about 3" long. Then I have two studs. One is about an inch long and I can see where it goes, and the other is a short one abour 1/2" with a retainer spring clip that goes through a hole in the stud and snaps over it. I think that was all I took off. My problem is I forget how this setup actually went and the manual has aweful drawings? Anybody got some better drawings or pictures of how these go together?
