cdwmotorsports
I am approaching a point in which I am considering redoing the entire wiring system in my Demon. It currently has a mixture of factory, CrackedBack’s MSD and my wiring. So none of the factory ignition wiring is used nor is the voltage regulator or alternator wiring is used. I have two BlueSea fuse boxes one is battery power fed and is feeding gauge lights, MSD, water pump, cooling fans, fuel pump and the other one is 12v keyed fed from the original radio power feed and runs the Dakota digital controller, and a couple other small item feeds. I really am not sure I want to cut the wires out of the factory harnesses as they are in good shape and intact currently. So I’m looking for input and ideas. I do have an engine harness from another car I would be totally cool with cutting up (72 Dart).
