[WANTED] '72 Duster 340 Door window up stop bracket passenger door rear top
Nuturner
Florida
I had posted this on open discussion and Dana67Dart and townsend were helping me and the site wouldn't let me respond. So, I'll try here.
Hello guys, I am putting my 72 Duster 340 back together after a rotisserie resto and I just realized that the passenger side rear window up stop assy. is NOT there! If anyone has one or may know a member who does, I am need of the entire stop. Bracket and Allen bolt. I have the bump stop bumper in place that secures in the glass. I would appreciate any assistance on this or I'll have to make one. Thanks!
My first picture is of the upper rear stop peg with the glass 3/4 up. The next picture is of the slotted hole in the door round opening where the Allen head bolt would hold the bracket and rubber foot. The last photo is of the drivers door and you can see the upper rear stop against the glass peg.
I removed the stop bracket from the drivers door. Of course the angle of the bracket and rubber stop would be 180 out but at least now we know kinda what it looks like. Thanks again guys, this group is awesome! The first phot is taken just like it is mounted in the d/s door. In 1 picture you can actually see the dent in the rubber stopper where it contacts the stop pin mounted in the glass.
In this image, 11,12,13,14 are the pieces in question I need. They are the ones to the rear and above the latch. Thank you
I have a 72
I looked on my 71 and cant see where this is. Is there a rubber piece covering this?
Could you step back from the door and get a larger area pic?
I have a 72
Yes the top weather strip piece ate the rear of the door held on by 3 Philips head screws covers the hole you see in my pic. If you take off the 3 screws the rubber piece can be removed without disturbing the weather strip that is attached to the rest of the door and you will see the bolt holding the stop bracket! Do you possibly have one of these for the passenger door upper rear? Thanks.
I can get a larger area pic tomorrow, the car is in the air the lift at the moment
To all the great members on this site, I have fortunate enough to find a member that has one and It is on it's way. Thanks again to all the responses. This is awesome!
