727 TRANS
GOOD MORNING
WHAT IS THE FACTORY BAND SIZE LEVER ???? 3.8 OR 4.2 OR SMALLER
It depends on the application. I've seen as small as 2.xx and as large as 4.xx. I think in trucks and performance cars you get the higher ratios.
A performance rebuild will always use the Hemi 4.2 lever for quicker, stronger band apply.
OK THANKS FOR THE HELP....ITS A NEW REBUILD BUT , NOTHING FANCY...I JUST INSTALLED A REV. MANUAL, SO IM JUST WONDERING WHAT IT MIGHT HAVE BEEN...
Hemi is 5.0, 4.2 was from a 273 Commando, I also have seen them down to the low 2's. While you are in there, check to see if it has a part throttle kickdown.
Would you have a source for the speedo housing o ring? Mine is leaking.
Thanks
