[SOLD] 73+ 26" two core OE radiator + fan shroud
junkyardhero
Los Angeles
this is an all brass 26" two core OE radiator for 73+ cars, it comes with a matching factory fan shroud and the fittings for transmission lines as seen.
this wasn't leaking, and doesn't show any signs of significant damage, however i haven't pressure tested it but water does flow thru it freely.
the shroud shows signs of contact with the fan at one time, but only superficial scrapes. there is a tiny hair line crack on the one side at the mount hole and some wear on the one lip at the top as shown in pictures. but other than that there are no cracks, chips or missing bits.
$250 + shipping, if you are within a reasonable distance i can deliver.
payment via paypal F&F, venmo, zelle or personal check with time to clear
bump.
still avail.
fyi, as for shipping be aware this thing is huge by large. 32" x 24 X 8" and comes in around 25lb with the shroud and box/packing material.
