73 340 duster Seat belt inner lock relay location.
flathead31coupe
indianapolis indiana
Does anyone know where The seatbelt interlock relay would have been mounted factory on a 73 duster.... Mine is just basically hanging there.Just curious it would have been from the factory
I didnt think the interlock came to market until the '74 model year.
If you are talking about the seatbelt and key-in buzzer, those are mounted up above the driver kick panel
ok, yeah. sounds like the interlock. I thought they were one year only for 74 but maybe your 73 was a late model year vehicle. They were located on the upper driver side apron
Are you sure your harnes/wiring in your car is original to the body?
You should just remove the interlock system
It looks to be original.
It also looks like the interlock stuff under the dash has been bypassed or something I know.
That it doesn't Work in the car still Starts and runs
You have an interesting mystery.
The dash wiring is definitely a 73 harness.
How about the date code on the left inner fender body tag.
