dgswinger
i have a 73 340 auto federal emissions # 6319s date code 230 2 this carb is in really good shape! it had a hygrade kit put in it about a year ago by a friend of mine that only runs thermoquads on his mopars!! it has sat on my work bench since then (it did get a little dusty) it has never had fuel thru it since or bolted to an intake since... you will get the rebuild kit papers and the base gaskets as well as the float height gauge. everything works smooth as it should! he said it was one of the best complete cores he had started with in while.
my project changed directions so i decided not to use it. just trying to recoupe some of my money i spent on my double pump holley!!
i will mention that i have no idea of how the tune is set up it was a stock rebuild! you will have to tune it to your engine...
asking price: $75 shipped to the 48 states
item located in south central pa.
