73 340 short block. Crank, rods, pistons. All standard bore and crank. The block will need 1 sleeve. Machine shop said .020 would clean it up, other than the sleeve. My plan was to go .020, cut down a 360 crank and turn it into a small stroker. I do have a fresh .010/.010 340 cast crank, that hasn't been used after turning. I also have a 360 crank I'll include if you want it that needs turning. So, 340. Spare (fresh) 340 crank and a 360 crank
Asking $450 for it all. I can not ship it and you need to pick it up.
Located in Milford, Delaware.
