73 Dart
Mopar73
New Member
Calgary
Hey all! New to the forum and looking for some input! I need some info on putting in a newer motor fuel injection and computer set up. Want to be able to plug my laptop into tweak it's performance. What will fit? What needs to be cut and added ? Any help as to where I need to find some information or pics of some of your projects! Thanks!
WElcome to FABO Mopar73. What engine are you running? The magnum engine wiring kits are available to work with stock ecu's.
Lots of EFI kits out there you could even check out the above forum.
Wanting to put in 6.1L Hemi. Probably a donor car ...write off but that way get Trans too. Anyone ever do this? I read somewhere about a motor mount kit?
