[Found!] 74+ A body disc brake spindles
roughidle
Super Platinum Member
Pennsylvania
Looking for a pair of disc brake spindles for a disc brake conversion on a 66 Coronet. Just looking for the spindles right now ('74+ A body disc brake spindles I'm told will do the trick). I'll be sourcing the rest of the components off the shelf. No rust or pitting on the shafts. Cleaned up or dirty, doesn't matter, just no rust scale. The closer to PA the better, but willing to have shipped. Let me know what you have available.
Thanks
I have a like new set up taken off of a 340 duster that is being changed back to small bolt. It was purchase as a kit with the power booster and proportioning valve. will split up or take it all. make me an offer. You won't have to source out anything. pick it up at Danielsville Pa. 18038. See what your paying for. Steve
I have a complete "K" member assembly from a 1974 Scamp. Only the ties rods are not part of the assembly. Any pieces can be removed.
I own both 66 & 67 Coronets and 70 thru 74 B-body spindles bolt on as well as the 73 up A body units--gives you alot more choises --72 Coronet disc setup is a sure thing--bolt it in
