[WANTED] 74 Duster door latch trim
Duster360LA
Texas
Looking for the interior door trim surround piece for a 1974 plymouth duster
This is the piece that surrounds the actual handle you use to open the door. Need a passenger side, but will buy both if you have a set. Would prefer black.
Ships to 78953 (Central Texas)
Will this one work? It's in a 1973 Duster in my junkyard. If I'm reading the parts catalogs correctly, it's the same part number (3695 204-5) between both years. Also, it seems to be the same part on both sides, whether its driver left door or passenger right door.
That appears to be the correct door handle bezels. How much do you want for it?
