ir3333
fronts...215 65R15 seems to ring a bell Don.
..A little wider than a 70 series a little shorter than a 225
First number is your "skinny" factor here.
i say if you want skinny - go for 205's personally i wouldnt go smaller than 225's
I would talk to them in the morning, 160 restocking fee is steep.
I sold wheels, new tires and lugs off my duster for $150
Also keep in mind even repo mopar wheels have the incorrect back space, most only have 4".
You can special order the correct back spacing / same style wheel from center line but expect to wait 6 months.
4.25" makes ever thing fit on a duster.
I reconditioned factory ones, keep in mind they came on everything trucks, cars.
The date code on mine are from 1985 so they came off a diplomat.
ARE you saying stay with the factory rally's that i have now ? WHAT is the b s on factory rim? on the box its says 6mm off set is that the 3 1/2 inch back space.
I run 15X7" front with 205/70R 15 and 15X8" rear with 255/60X15 all on American racing Ventura wheels, back space is 4.75 I think.
