'77 rv 360 motor swap to '74 DUSTER
Mopar...{MUSCLE}
New Member
Buckeye,Az
How's it going MOPAR dude's??
Alright, im going to pull the rv 360 and drop it into the duster soon and I am wondering if there is anything else i need to look out for other than the oil pan and motor mounts??
Do I buy an oil pan for a 360 duster or will it not fit due to it being an rv/truck block??
I heard I can use the 318 mounts but shim them to fit, is this correct??
if not what mounts do I buy them for a 360 duster??
I'll keep you all up dated on the swap.:read2:
Anything else from you MOPAR fanatics:cheers: would be greatly appreciated!!
Thanks, Jr.
Blocks are the same truck and car
If you dont use the rv tranny or a factory 360 torque converter then you will need a b&m weighted flex plate so you can use any neutral blance torque converter
