8 1/4 1972 dodge dart rearend
panthro72
Member
watertown
worth building this up or go for the larger 8 3/4 this also has the small bolt pattern and a slightly upgraded 273 in front of it ?
8.25 rears a decent rears but you get that one gear only. However if you plan to drive to the track race and drive back 8.75 rears offer quick change of gears like 3.23 to get to the track, bolt in the 3.91s or 4.10 and swap back to the 3.23 and drive home
If it's SBP it's not an 8.25. Should be a 7.25. It might last and might not behind a mild 273.
