bruue1
New Member
8 3/4 66-70 B Body Axle 742 case 2.76 new Sure Trac, Green Axle Bearings, Axles, Disc Brakes, Seals, Diff bearings $1500
Parts from Dr Diff
Finish is good wire brushing, por 15, Semi Gloss Rustoleum Top Coat, it looks as good in person.
Center to Center perches are 44"
Flange to Flange is 55"
Has assembly lube and spins freely, has not had gear lube put in it yet.
I have a bottle of friction modifier to go with it.
I got the lash right but I built in my garage, no guarantees for you, it is all new and beautiful inside, easy to adjust if you felt the need
You can have the cart it is sitting on along with the old axles and old open diff too if desired
I also have a pair of excellent condition OEM B Body shock plates and a brand new still wrapped set of 5 leaf F Body leaf springs that have B Body centering pins custom made from Espo n Springs, these springs also provide a 2" lift.
If you want these parts we can discuss a deal.
I'm only selling because I recently sold the 1980 Dodge Aspen Sedan I collected these parts for.
I'm posting on this forum because I'm pretty sure you A Body guys like this year and model 8 3/4, forgive me if I'm mistaken.
Cross posted locally in Twin Cities MN, cash in person pick up
Thanks for your time
Have a good day
Parts from Dr Diff
Have a good day
