[FOR SALE] 8 3/4 Axles
66Kooda
Patriot
Rating - 0%
0   0   0
I have (2) factory axles for 8 3/4 with new green bearings installed. I ended up having Moser cut the housing down and purchased new ones instead. They are 30 spline and measure 28 9/16 from the back of the flange. New studs installed.
$250 plus the ride.
Last question...
B, E body brake backing plate spacing
Or A body spacing
So your saying these fit a factory A body housing? Thanks. Kim
They cam out of a 67 B body 8 3/4 housing. I’m not sure if they work in a 8 3/4 A body housing. You would have to verify the axle length.
